Cheers for the reply mate. They say things come in 3s and this evening my wipers have decided to stop working so off will have to try fix that as well. French electrics ehSounds like the final stage resistor, common issue.
Chees mate, they only stopped working last night and i was thinking that could be the issue as have checked all fuses and they seem to be fine. Will be getting to removing it today and cleaning it outJust a thought with you mentioning the wipers now not working.... have you checked the drains under the scuttle panel aren't blocked?? Electrical faults can often be caused by the drains blocking and water affecting things, especially the wipers, as the motor is right where water can gather.
As I say, just a thought that popped into my head - you may have already checked this, but I thought it was worth flagging up. Best of luck getting it sorted.
I have just finished clearing the drains which were blocked. The was a lot of water and i think the motor at points when turning etc would have been in contact with a lot of water so that may be the issue? But still not working so no driving for a few days until i can get my mate to take a proper look at it for me. Will try chamging fuses in the mean time. Will keep updating. Cheers for the help fellas
Hi mate. Yea gunna fit the motor right now actually. Fingers crossed that sorts itI'm glad the suggestion helped out, I had a suspicion that it could be that. Hopefully your friend can get it completely sorted for you.
Wow thats cheap definitely will! I am a tradesman myself so i shall pop into my local toolstation tomorrow after work and grab one. Any ideas what it could be?A bit of a trek for me I'm afraid. If you can pick up one of these I can help you narrow it down without having to spend much money.
://www.toolstation.com/shop/p84459
I did check the fuses abd they all seemed fine but maybe i missed one or somethingWell first to check is voltage to one of the pins on the motor when wipers are put on full whack. If no voltage then trace back to relay and fuse. I believe there is a 20 amp fuse in the engine bay which supplies the wipers. I'd put money on it being on a fuse after short circuited due to the water.
S | Clio 197 in Racing Blue FSH 65k £5,500 | Clios For Sale | 1 | |
Piston Heads 197 Track Car auction. | Clio General Chat | 4 | ||
Wiring Diagram for 197/200 Wipers | Body Work and Exterior Lights | 1 | ||
M | Clio 197 heater | New Members | 1 | |
P | Heater Resistor 197 | Interior and Audio | 9 |
