Hello all!
@tombate911 has a copy one off eBay (I believe) and that looks smart! I'm being patient, I'll get one eventually but bottom of the pile!
Yeah i've got an Italian copy. It took a lot of prep work to get it to paint as they must use something in the mould when making them which reacts with the paint. few coats of paint and flatting back and it's ok now.
So just fitted the map sensor, it defiantly felt better, only slight flat spot at 2500 idle sounded better went around a rounderbout and it was awful! But I had traction on turned it off and seems better now!?
Reactions: Big Ben
Have you checked if it is decatted or not yet?
Also, is it a resonated or non-resonated system?
If these haven’t been mapped in (even though I know you’ve been told they have) that could be causing your flat spot.
(I’m sure some 197/200 people will be along to tell me I’m wrong, but I’m sure I can recall that from my 197 days years ago [emoji23])
It's still got the cat just been over to ktec and they sold me a second hand miltek decat pipe! So il fit this and see what happens, while I was there I needed up buying a cup spoiler! Haha
Reactions: M19TNR and Beany
Chances are it might well make your flat spot worse. I’d try and find out what’s causing it before fitting more stuff.
@M19TNR is bang on. My induction kit was fitted before I had it all mapped and it was horrific.
Reactions: M19TNR
It was really to see if it made it any better as there is paper work to say it's mapped with a cat, that's the only reason
Reactions: M19TNR
Here is a pic under my car to me it looks like it has a decat!?
C New Members 4
N New Members 4
M New Members 5
Anthony9219 New Members 17
Slint New Members 9
