Ohh yess. Some people like carpets and alcantara seats and dash board... but this is more me! Makes me want to get the cage on order and get mine all done! Which compressor and gun did you use?
I have a good 150litre compressor and it's just a cheap gun. No need for anything expensive when you're not using them all the time. Think it was only a £10-£15!
My new material to make the footwell false floors has arrived. So will update with pics shortly.
Well while I can't do anything much at the moment I've still managed to make some progress. I've ordered a load of new parts from Helix, Forge & TTV. I've also dropped the gearbox off for a check over and for an uprated 3rd synchro ring before it goes back in and also sent the front subframe off for shot blast and powder coat. Some progress at least!
I've bought phenolic board and am going to make a custom fitted set to my own spec and dimensions. I had thought about ordering the carbon fibre ones you can get from carbotec as I had something similar before in my 106 but decided against them.
Would be good to see some of your designs/mock ups for them. For the moment I have just bolted in a bit of sheet aluminium which does the job, but I don't like the look of it and I'm pretty OCD even with a bare metal interior!
