No power to Radio or Temperature / Clock display?
My car was involved in a hit and run accident 6 weeks ago, after finally getting it back from the bodyshop last Thursday (with it being sat in storage for 4 weeks), the battery was disconnected, and reconnected before I took the keys back. No other warning lights are on and the car drives fine, however I have no power to the CD player / Radio OR to the temperature display / clock / track info above it.
The reason this wasn't discovered initially is that it had a Pioneer CD unit in it with the faceplate removed while the work was done. I have now reconnected the original CD player (thinking the code was needed), but again no power to either display.
Suggestions?
Cheers
Anthony.
two fuse boxes....
1 in the interior and the other in the engine bay - need to check them
theres a fuse hidden in behind the glovebox for all these things. That was the problem with mine when i just randomly lost all power to the centre part of the dash.
Reactions: dozydinosaur
